The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
diskown.assignexceeded events
Creating your file...
Your file is ready
diskown.AssignExceeded
- Severity
ERROR
- Description
This message occurs when an attempt is made to assign more disks than are supported by this node.
- Corrective Action
Review the system capacity limits and the assigned disks on this system.
- Syslog Message
The maximum number of disks that can be assigned to this node has been exceeded. Attempted to assign %d, maximum supported: %d.
- Parameters
attempted (INT): Number of disks attempted to assign.
supported (INT): Number of disks supported.
