The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
cf.badshelfcountversion events
Creating your file...
Your file is ready
cf.badShelfCountVersion
- Severity
ERROR
- Description
This event occurs if we are sent a negotiated failover shelf count message with a version which we don't support. As a result, disk shelf count negotiated failover will not work. This is likely due to a kernel version mismatch.
- Corrective Action
Upgrade the down-rev node so both nodes are on the same version.
- Syslog Message
Disk shelf count message with unsupported version received from partner.
- Parameters
(None).
