      cf.badshelfcountversion events
cf.badShelfCountVersion
- Severity
ERROR
 - Description
This event occurs if we are sent a negotiated failover shelf count message with a version which we don't support. As a result, disk shelf count negotiated failover will not work. This is likely due to a kernel version mismatch.
 - Corrective Action
Upgrade the down-rev node so both nodes are on the same version.
 - Syslog Message
Disk shelf count message with unsupported version received from partner.
 - Parameters
(None).
