ONTAP EMS reference
sis.compress events
sis.compress.skip
Severity
INFORMATIONAL
This message occurs when postprocess compression is skipped during a deduplication operation, even though postprocess compression is enabled on the volume. Post process compression is not supported on a node configured with the All-Flash Optimized personality.
Corrective Action
(None).
Syslog Message
Skipped postprocess compression on volume %s%s because the node is All-Flash Optimized.
path (STRING): Path to the deduplicated volume.
volident (STRING): Unique volume identifier.
