The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
sis.compress events
Creating your file...
Your file is ready
sis.compress.skip
- Severity
INFORMATIONAL
- Description
This message occurs when postprocess compression is skipped during a deduplication operation, even though postprocess compression is enabled on the volume. Post process compression is not supported on a node configured with the All-Flash Optimized personality.
- Corrective Action
(None).
- Syslog Message
Skipped postprocess compression on volume %s%s because the node is All-Flash Optimized.
- Parameters
path (STRING): Path to the deduplicated volume.
volident (STRING): Unique volume identifier.
