The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
reg.errno events
Creating your file...
Your file is ready
reg.errno.addAfterReadable
- Severity
NOTICE
- Description
This event is issued when Data ONTAP(tm) cannot add an errno-style error to the list of errors. The error must be added before the readable version is generated. No action by the system administrator is needed.
- Corrective Action
(None).
- Syslog Message
registry: ignoring attempt to add an error (%d) after errors_readable was called.
- Parameters
errnoval (INT): The numerical value of the error.
reg.errno.addInvalid
- Severity
NOTICE
- Description
This event is issued when Data ONTAP(tm) cannot add an errno-style error to the list of errors. The error number must be non-zero or the error string must be non-NULL. No action by the system administrator is needed.
- Corrective Action
(None).
- Syslog Message
registry: in errors_add_real, errnoval must be non-zero or str must be non-NULL.
- Parameters
(None).
