ONTAP EMS reference
wafl.i2p events
wafl.i2p.entries.mismatch
Severity
NOTICE
This message occurs when the ONTAP® kernel detects that an i2p metafile on one of the snapshot has more entries than necessary for an inode.
Corrective Action
(None).
Syslog Message
There are more entries in the i2p metafile than there should be in volume %s%s%s%s, for inode %d in snapshot %d.
owner (STRING): Owner of the volume.
vol (STRING): Name of the volume.
app (STRING): Application UUID.
volident (STRING): Unique identifier for the volume in cases where the volume name itself is insufficient.
fileid (INT): Identifying number for the suspect inode.
snapid (INT): The snapshot identifier.
wafl.i2p.fix.parent.pointer
Severity
NOTICE
This message occurs when an inode-to-parent (i2p) scan detects and rectifies an incorrect parent inode number or cookie in an inode while fixing i2p data in a converted directory.
Corrective Action
(None).
Syslog Message
%s %s%s%s%s: Inode %u, fixing parent pointer, was: (parent: %u, cookie: 0x%x).
type (STRING): Type of object (volume or aggregate).
owner (STRING): Volume owner.
vol (STRING): Volume name.
volident (STRING): Unique identifier of the volume in cases where the volume name itself is insufficient.
inode (INT): Inode number.
old_parent_inode (INT): Existing parent inode number.
old_cookie (INT): Existing parent cookie.
