wafl.i2p events
wafl.i2p.entries.mismatch
- Severity
NOTICE
- Description
This message occurs when the ONTAP® kernel detects that an i2p metafile on one of the snapshot has more entries than necessary for an inode.
- Corrective Action
(None).
- Syslog Message
There are more entries in the i2p metafile than there should be in volume %s%s%s%s, for inode %d in snapshot %d.
- Parameters
owner (STRING): Owner of the volume.
vol (STRING): Name of the volume.
app (STRING): Application UUID.
volident (STRING): Unique identifier for the volume in cases where the volume name itself is insufficient.
fileid (INT): Identifying number for the suspect inode.
snapid (INT): The snapshot identifier.
wafl.i2p.fix.parent.pointer
- Severity
NOTICE
- Description
This message occurs when an inode-to-parent (i2p) scan detects and rectifies an incorrect parent inode number or cookie in an inode while fixing i2p data in a converted directory.
- Corrective Action
(None).
- Syslog Message
%s %s%s%s%s: Inode %u, fixing parent pointer, was: (parent: %u, cookie: 0x%x).
- Parameters
type (STRING): Type of object (volume or aggregate).
owner (STRING): Volume owner.
vol (STRING): Volume name.
volident (STRING): Unique identifier of the volume in cases where the volume name itself is insufficient.
inode (INT): Inode number.
old_parent_inode (INT): Existing parent inode number.
old_cookie (INT): Existing parent cookie.
