ONTAP EMS reference
netinet6.icmp events
netinet6.icmp EMS events occur when ONTAP encounters issues associated with ICMPv6 message processing.
netinet6.icmp.chksum
Severity
ERROR
This message occurs when the system receives an Internet Control Message Protocol(ICMP) message, and while processing the ICMP message it finds a checksum error.
Corrective Action
(None).
Syslog Message
ICMP6 checksum error (%d|%x) %s.
icmpType (INT): ICMP header type field.
checksum (INTHEX): Checksum value.
ipAddress (STRING): Printable that is a loggable representation of IP address.
netinet6.icmp.redirect
Severity
NOTICE
This message occurs when an ICMPv6 redirect message is received. The redirect might be received due to either a misconfigured route or a man-in-the-middle ICMP redirect attack.
Corrective Action
When enabled, ICMP redirects can be disabled using the "network tuning icmp6 modify -is-v6-redirect-accepted false" command. However, disabling ICMP redirects might lead to connectivity problems or longer delays of data transfers.
Syslog Message
Received %lu ICMPv6 redirect messages for IPspace "%s".
no_of_redirects (LONGINT): Total number of ICMPv6 redirects received for the specific IPspace.
ipspace (STRING): The IPspace for which the redirect packets are received.
netinet6.icmp.reject.equal
Severity
ERROR
This message occurs when the system rejects a redirect because both router case and on-link destination case are equal.
Corrective Action
(None).
Syslog Message
ICMP6 redirect rejected; neither router case nor onlink case: %s.
addressBuff (STRING): Contains IP6 addresses.
netinet6.icmp.reject.length
Severity
INFORMATIONAL
This message occurs when there is a lladdrlen mismatch for the specified IP6 address.
Corrective Action
(None).
Syslog Message
icmp6_redirect_input: lladdrlen mismatch for %s (if %d, icmp6 packet %d): %s.
ip6address (STRING): Printable that is a loggable representation of the IP address.
mediaAddrlen (INT): Media address length.
lladdrlen (INT): Address length.
Severity
ERROR
This message occurs when the system rejects an Internet Control Message Protocol6 (ICMP6) redirect.
Corrective Action
(None).
Syslog Message
ICMP6 redirect sent from %s rejected;It must be from the linklocal address.
ipAddress (STRING): Printable that is a loggable representation of the IP address.
netinet6.icmp.reject.ndopt
Severity
INFORMATIONAL
This message occurs because of invalid neighbor discovery options.
Corrective Action
(None).
Syslog Message
icmp6_redirect_input: Invalid neighbor discovery option, rejected: %s.
