config.diffpool events
config.diffpool EMS events occur when a disk is found to be multipathed to two different mirroring pools.
config.DiffPool
- Severity
ALERT
- Description
This message occurs when a disk is found to be multipathed to two different mirroring pools. This configuration is illegal.
- Corrective Action
See the NetApp technical support site for guidelines about assigning disks or array LUNs to SyncMirror® pools.
- Syslog Message
Disk %s is dual-attached to two separate mirrored pools. This is an illegal configuration.
- Parameters
disk (STRING): Name of the disk.
