ONTAP EMS reference
config.diffpool events
config.diffpool EMS events occur when a disk is found to be multipathed to two different mirroring pools.
config.DiffPool
Severity
ALERT
This message occurs when a disk is found to be multipathed to two different mirroring pools. This configuration is illegal.
Corrective Action
See the NetApp technical support site for guidelines about assigning disks or array LUNs to SyncMirror® pools.
Syslog Message
Disk %s is dual-attached to two separate mirrored pools. This is an illegal configuration.
disk (STRING): Name of the disk.
