The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
config.diffpool events
Creating your file...
Your file is ready
config.DiffPool
- Severity
ALERT
- Description
This message occurs when a disk is found to be multipathed to two different mirroring pools. This configuration is illegal.
- Corrective Action
See the NetApp technical support site for guidelines about assigning disks or array LUNs to SyncMirror® pools.
- Syslog Message
Disk %s is dual-attached to two separate mirrored pools. This is an illegal configuration.
- Parameters
disk (STRING): Name of the disk.
