ONTAP EMS reference
sv.vol events
SV.vol.snapshot.rename.error
Severity
ERROR
This message occurs when the renaming operation of SnapVault® Snapshot(tm) copies belonging to a certain volume fails, even though the "vFiler rename" or "vFiler move" operation was successful. The problem might be that the volume was offline during the "vFiler rename" or "vFiler move" operation, and it might cause SnapVault to have an extra Snapshot copy on the destination. To avoid this scenario, volumes need to be online during a "vFiler rename" or "vFiler move".
Corrective Action
If necessary, delete the extra Snapshot copy manually after the next SnapVault update.
Syslog Message
Rename of SnapVault snapshots for volume %s failed. This might cause SnapVault to have an extra snapshot on destination. If necessary, delete the extra Snapshot copy manually after the next SnapVault update.
vol_name (STRING): Volume whose Snapshot copies created by SnapVault® could not be renamed.
