sp.postupd events
Creating your file...
Your file is ready
sp.postupd.ck.unexpt.sp.rev
- Severity
ERROR
- Description
This message occurs after a scheduled firmware update, when the servprocd daemon detects that the Service Processor(SP) firmware version changed to an unexpected value.
- Corrective Action
Check whether the SP firmware has been updated through the SP CLI. If not: 1. Manually update the SP firmware. 2. If the failures persist, contact NetApp technical support.
- Syslog Message
%s.
- Parameters
reason (STRING): Reason for the failure: %s.
