ONTAP EMS reference
sp.postupd events
sp.postupd EMS events occur after a scheduled firmware update, when the servprocd daemon detects that the Service Processor(SP) firmware version changed to an unexpected value.
sp.postupd.ck.unexpt.sp.rev
Severity
ERROR
This message occurs after a scheduled firmware update, when the servprocd daemon detects that the Service Processor(SP) firmware version changed to an unexpected value.
Corrective Action
Check whether the SP firmware has been updated through the SP CLI. If not: 1. Manually update the SP firmware. 2. If the failures persist, contact NetApp technical support.
Syslog Message
%s.
reason (STRING): Reason for the failure: %s.
