config.differentswitchport events
config.differentswitchport EMS events occur when the two ports of the disk are connected to different switch ports.
config.DifferentSwitchPort
- Severity
ALERT
- Description
This message occurs when the two ports of the disk are connected to different switch ports.
- Corrective Action
(None).
- Syslog Message
Disks on port %s:%d are also connected to port %s:%d. They need to be connected via the same port on different switches. This is an illegal configuration.
- Parameters
switch1 (STRING): (None).
port1 (INT): (None).
switch2 (STRING): (None).
port2 (INT): (None).
