ONTAP EMS reference
netif.linkdown events
netif.linkdown EMS events occur when a network link goes down or the interface is not operational when first configured up.
netif.linkDown
Severity
INFORMATIONAL
This message occurs when a network link goes down or the interface is not operational when first configured up.
Corrective Action
If the message describes the link as "down," check the cabling and switch port configuration. If the message states "controller initialization failure", report this to NetApp technical support.
Syslog Message
%s %s: Link %s.
lanType (STRING): Local area network (LAN) type.
ifName (STRING): Name of the network interface.
status (STRING): Brief information about the problem.
