ONTAP EMS reference
config.more2path events
config.More2Path
Severity
ERROR
This message occurs when a disk is found to have more than two connections to the storage controller.
Corrective Action
Remove connections to the disk so there are only two.
Syslog Message
Disk %s and other disks on this loop/domain are attached with more than two connections. Only two connections are supported.
disk (STRING): Name of the disk.
