The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
config.more2path events
Creating your file...
Your file is ready
config.More2Path
- Severity
ERROR
- Description
This message occurs when a disk is found to have more than two connections to the storage controller.
- Corrective Action
Remove connections to the disk so there are only two.
- Syslog Message
Disk %s and other disks on this loop/domain are attached with more than two connections. Only two connections are supported.
- Parameters
disk (STRING): Name of the disk.
