upgrademgr.fw events
upgrademgr.fw.monitor.end
Severity
NOTICE
This message occurs when an automated nondisruptive upgrade (ANDU) completes the firmware update monitoring job.
Corrective Action
(None).
Syslog Message
ANDU firmware update monitoring job completed. Status: %s.
status (STRING): Status of overall firmware monitoring job.
upgrademgr.fw.monitor.start
Severity
NOTICE
This message occurs when an automated nondisruptive upgrade (ANDU) starts a firmware update monitoring job.
Corrective Action
(None).
Syslog Message
ANDU firmware update monitoring job started.
(None).
upgrademgr.fw.unsupported
Severity
NOTICE
This message occurs when an automated nondisruptive upgrade (ANDU) runs on a platform that does not have SP/BMC API support.
Corrective Action
(None).
Syslog Message
ANDU firmware update monitoring job skipped because "%s"
reason (STRING): ANDU firmware monitoring is not supported on this platform.
upgrademgr.fw.update.fail
Severity
ERROR
This message occurs when a firmware update has failed for any of the firmware components.
Corrective Action
Contact Contact NetApp technical support. for assistance.
Syslog Message
ANDU firmware update failed for firmware component: %s. Status: %s.
firmware_name (STRING): Firmware component whose update has failed.
status (STRING): Category of failure for the firmware component whose update has failed.
