ONTAP EMS reference
upgrademgr.fw events
upgrademgr.fw EMS events occur when ONTAP encounters issues associated with automated nondisruptive upgrade (ANDU) firmware updates.
upgrademgr.fw.monitor.end
Severity
NOTICE
This message occurs when an automated nondisruptive upgrade (ANDU) completes the firmware update monitoring job.
Corrective Action
(None).
Syslog Message
ANDU firmware update monitoring job completed. Status: %s.
status (STRING): Status of overall firmware monitoring job.
upgrademgr.fw.monitor.start
Severity
NOTICE
This message occurs when an automated nondisruptive upgrade (ANDU) starts a firmware update monitoring job.
Corrective Action
(None).
Syslog Message
ANDU firmware update monitoring job started.
(None).
upgrademgr.fw.unsupported
Severity
NOTICE
This message occurs when an automated nondisruptive upgrade (ANDU) runs on a platform that does not have SP/BMC API support.
Corrective Action
(None).
Syslog Message
ANDU firmware update monitoring job skipped because "%s"
reason (STRING): ANDU firmware monitoring is not supported on this platform.
upgrademgr.fw.update.fail
Severity
ERROR
This message occurs when an automatic non-disruptive upgrade (ANDU) operation is paused due to a firmware update failure. The issue has to be resolved before the ANDU operation can continue.
Corrective Action
Contact NetApp technical support.
Syslog Message
ANDU firmware update failed for firmware component: %s. Status: %s.
firmware_name (STRING): Firmware component whose update has failed.
status (STRING): Category of failure for the firmware component whose update has failed.
