upgrademgr.fw events
upgrademgr.fw EMS events occur when ONTAP encounters issues associated with automated nondisruptive upgrade (ANDU) firmware updates.
upgrademgr.fw.monitor.end
- Severity
NOTICE
- Description
This message occurs when an automated nondisruptive upgrade (ANDU) completes the firmware update monitoring job.
- Corrective Action
(None).
- Syslog Message
ANDU firmware update monitoring job completed. Status: %s.
- Parameters
status (STRING): Status of overall firmware monitoring job.
upgrademgr.fw.monitor.start
- Severity
NOTICE
- Description
This message occurs when an automated nondisruptive upgrade (ANDU) starts a firmware update monitoring job.
- Corrective Action
(None).
- Syslog Message
ANDU firmware update monitoring job started.
- Parameters
(None).
upgrademgr.fw.unsupported
- Severity
NOTICE
- Description
This message occurs when an automated nondisruptive upgrade (ANDU) runs on a platform that does not have SP/BMC API support.
- Corrective Action
(None).
- Syslog Message
ANDU firmware update monitoring job skipped because "%s"
- Parameters
reason (STRING): ANDU firmware monitoring is not supported on this platform.
upgrademgr.fw.update.fail
- Severity
ERROR
- Description
This message occurs when an automatic non-disruptive upgrade (ANDU) operation is paused due to a firmware update failure. The issue has to be resolved before the ANDU operation can continue.
- Corrective Action
Contact NetApp technical support.
- Syslog Message
ANDU firmware update failed for firmware component: %s. Status: %s.
- Parameters
firmware_name (STRING): Firmware component whose update has failed.
status (STRING): Category of failure for the firmware component whose update has failed.
