      rpl.check events
rpl.check.unusable.log.file
- Severity
ERROR
 - Description
This message occurs when SnapMirror® Fixer detects inconsistency in the verifier log file generated by a previous SnapMirror 'check' operation. The SnapMirror 'fixer' operation will be terminated.
 - Corrective Action
Run the SnapMirror 'fixer' command.
 - Syslog Message
The SnapMirror verifier log is inconsistent and could not be used.
 - Parameters
(None).
