rpl.check events
rpl.check.unusable.log.file
Severity
ERROR
This message occurs when SnapMirror® Fixer detects inconsistency in the verifier log file generated by a previous SnapMirror 'check' operation. The SnapMirror 'fixer' operation will be terminated.
Corrective Action
Run the SnapMirror 'fixer' command.
Syslog Message
The SnapMirror verifier log is inconsistent and could not be used.
(None).
