rpl.check events
rpl.check EMS events occur when SnapMirror® Fixer detects inconsistency in the verifier log file generated by a previous SnapMirror 'check' operation.
rpl.check.unusable.log.file
- Severity
ERROR
- Description
This message occurs when SnapMirror® Fixer detects inconsistency in the verifier log file generated by a previous SnapMirror 'check' operation. The SnapMirror 'fixer' operation will be terminated.
- Corrective Action
Run the SnapMirror 'fixer' command.
- Syslog Message
The SnapMirror verifier log is inconsistent and could not be used.
- Parameters
(None).
