The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
diskown.assign events
Creating your file...
Your file is ready
diskown.assign.splitOwner
- Severity
INFORMATIONAL
- Description
This message occurs when the "storage disk assign" command fail to assign a disk to a different owner from the other disks within the carrier. This is because the "storage disk assign" command with the -f option must be used in such cases.
- Corrective Action
Use the "storage disk assign" command with the -f option to assign the disk to a different owner from the other disks within the carrier.
- Syslog Message
Assigning ownership failed for disk %s. Use the "storage disk assign" command with the -f option to assign the disk to a different owner from the other disks within the carrier.
- Parameters
diskname (STRING): Name of the disk.
