diskown.assign events
diskown.assign EMS events occur when the "storage disk assign" command fail to assign a disk to a different owner from the other disks within the carrier.
diskown.assign.splitOwner
- Severity
INFORMATIONAL
- Description
This message occurs when the "storage disk assign" command fail to assign a disk to a different owner from the other disks within the carrier. This is because the "storage disk assign" command with the -f option must be used in such cases.
- Corrective Action
Use the "storage disk assign" command with the -f option to assign the disk to a different owner from the other disks within the carrier.
- Syslog Message
Assigning ownership failed for disk %s. Use the "storage disk assign" command with the -f option to assign the disk to a different owner from the other disks within the carrier.
- Parameters
diskname (STRING): Name of the disk.
