ONTAP EMS reference
ses.mismatch events
ses.mismatch EMS events occur when the two disk shelf modules within the same disk shelf are running different versions of the firmware.
ses.mismatch.fw.version
Severity
ERROR
This message occurs when the two disk shelf modules within the same disk shelf are running different versions of the firmware.
Corrective Action
Download the latest disk shelf firmware to the disk shelf module that is not up-to-date.
Syslog Message
The disk shelf modules on disk shelf %s.%d are running two different firmware versions. Disk shelf module A is running %s, and disk shelf module B is running %s.
channelName (STRING): Name of the adapter port or switch port.
shelfID (INT): ID of the disk shelf.
revision_str (STRING): Revision number for disk shelf module A, the top disk shelf module.
revision_str2 (STRING): Revision number for disk shelf module B, the bottom disk shelf module.
