The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
ses.mismatch events
Creating your file...
Your file is ready
ses.mismatch.fw.version
- Severity
ERROR
- Description
This message occurs when the two disk shelf modules within the same disk shelf are running different versions of the firmware.
- Corrective Action
Download the latest disk shelf firmware to the disk shelf module that is not up-to-date.
- Syslog Message
The disk shelf modules on disk shelf %s.%d are running two different firmware versions. Disk shelf module A is running %s, and disk shelf module B is running %s.
- Parameters
channelName (STRING): Name of the adapter port or switch port.
shelfID (INT): ID of the disk shelf.
revision_str (STRING): Revision number for disk shelf module A, the top disk shelf module.
revision_str2 (STRING): Revision number for disk shelf module B, the bottom disk shelf module.
