ic.unsupportcable events
ic.unsupportCable
Severity
ERROR
This message occurs when an unsupported cable is detected on the high-availability interconnect port. An unsupported cable might cause the interconnect to be unstable, resulting in unsynchronized logs.
Corrective Action
Unplug the unsupported cable, and then plug in a supported cable. Search the support site "Hardware Universe" for information about supported high-availability cables for this platform.
Syslog Message
Detected unsupported %s cable with part number %s.
cable_type (STRING): Cable type.
cable_part (STRING): Cable part number.
