ic.unsupportcable events
Creating your file...
Your file is ready
ic.unsupportCable
- Severity
ERROR
- Description
This message occurs when an unsupported cable is detected on the high-availability interconnect port. An unsupported cable might cause the interconnect to be unstable, resulting in unsynchronized logs.
- Corrective Action
Unplug the unsupported cable, and then plug in a supported cable. Search the support site "Hardware Universe" for information about supported high-availability cables for this platform.
- Syslog Message
Detected unsupported %s cable with part number %s.
- Parameters
cable_type (STRING): Cable type.
cable_part (STRING): Cable part number.
