The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
ic.unsupportcable events
Creating your file...
Your file is ready
ic.unsupportCable
- Severity
ERROR
- Description
This message occurs when an unsupported cable is detected on the high-availability interconnect port. An unsupported cable might cause the interconnect to be unstable, resulting in unsynchronized logs.
- Corrective Action
Unplug the unsupported cable, and then plug in a supported cable. Search the support site "Hardware Universe" for information about supported high-availability cables for this platform.
- Syslog Message
Detected unsupported %s cable with part number %s.
- Parameters
cable_type (STRING): Cable type.
cable_part (STRING): Cable part number.
