      shelf.reset events
shelf.reset.counters
- Severity
INFORMATIONAL
 - Description
This message occurs when ONTAP® software resets the error counters on a disk shelf module.
 - Corrective Action
(None).
 - Syslog Message
Resetting error counters for module %s in disk shelf %s.%d.
 - Parameters
element (STRING): Disk shelf module designator (A is the upper module, B is the lower module).
channel (STRING): Channel the disk shelf module is on.
shelfID (INT): ID of the disk shelf the module is in.
