The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
shelf.reset events
Creating your file...
Your file is ready
shelf.reset.counters
- Severity
INFORMATIONAL
- Description
This message occurs when ONTAP® software resets the error counters on a disk shelf module.
- Corrective Action
(None).
- Syslog Message
Resetting error counters for module %s in disk shelf %s.%d.
- Parameters
element (STRING): Disk shelf module designator (A is the upper module, B is the lower module).
channel (STRING): Channel the disk shelf module is on.
shelfID (INT): ID of the disk shelf the module is in.
