nblade.junctionrootlookup2 events
Creating your file...
Nblade.JunctionRootLookup2
- Severity
ERROR
- Description
This message occurs when the system cannot obtain the root file handle of the volume mounted on a junction path. The cause of the problem might be that the target node is down or the target volume or aggregate is offline. The typical client operation that triggers a junction root lookup is a directory list operation where one of the directory entries is a junction. As long as the root of the volume at the junction cannot be looked up, the NFS client that is listing the directory appears to hang.
- Corrective Action
Check whether the volume or aggregate or node that matches the given MSID is offline. If it is, bring it online if possible.
- Syslog Message
Junction root lookup of a volume in Vserver %llu with MSID %llu has failed for reason "%s".
- Parameters
vserverId (LONGINT): Vserver for this Master Data Set ID (MSID).
msid (LONGINT): MSID of the volume mounted at the junction being looked up.
reason (STRING): Additional information about why the operation failed.
