nblade.flexgroupstatefulprotocolaccess events
Nblade.flexgroupStatefulProtocolAccess
- Severity
ERROR
- Description
This message occurs when a client tries to access a FlexGroup through a stateful protocol, like SMB1. Currently only NFSv3 mounts and SMB2+ share are supported by FlexGroups.
- Corrective Action
Make sure a FlexGroup supported protocol is specified for all client mount operations through which a FlexGroup can be accessed. If using NFSv3, consider specifying 'nfsvers=3' as an option for the 'mount' command on all clients accessing a FlexGroup.
- Syslog Message
Attempt to access FlexGroup with MSID %u with %s denied.
- Parameters
msid (INT): MSID of the FlexGroup being accessed.
protocol (STRING): Client protocol.
