The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
nblade.fpolpassthrudisconn events
Creating your file...
Your file is ready
Nblade.fpolPassthruDisconn
- Severity
INFORMATIONAL
- Description
This message occurs when the pass-through read channel between the node and the FPolicy server is disconnected.
- Corrective Action
(None).
- Syslog Message
Pass-through read channel with the FPolicy server is disconnected. Vserver ID [%d], FPolicy server IP address [%s], Disconnect reason [%s].
- Parameters
vserverId (INT): Identifier for the Vserver associated with this operation.
fpserverIp (STRING): IP address of the FPolicy server.
disconnReason (STRING): Reason for disconnection.
