nblade.fpolpassthrudisconn events
Creating your file...
Your file is ready
Nblade.fpolPassthruDisconn
- Severity
INFORMATIONAL
- Description
This message occurs when the pass-through read channel between the node and the FPolicy server is disconnected.
- Corrective Action
(None).
- Syslog Message
Pass-through read channel with the FPolicy server is disconnected. Vserver ID [%d], FPolicy server IP address [%s], Disconnect reason [%s].
- Parameters
vserverId (INT): Identifier for the Vserver associated with this operation.
fpserverIp (STRING): IP address of the FPolicy server.
disconnReason (STRING): Reason for disconnection.
