ONTAP EMS reference
perf.ccma events
perf.ccma EMS events occur when ONTAP encounters issues associated with the performance archiver.
perf.ccma.off
Severity
ALERT
This message occurs when the performance archiver is not enabled.
Corrective Action
Enable the performance archiver to track system activity and allow technical support to troubleshoot performance problems. To re-enable, run the 'archive config modify -is-enabled true' command.
Syslog Message
Performance archiver is not enabled for datastore '%s'.
datastore (STRING): Datastore name.
perf.ccma.startupFailed
Severity
ALERT
This message occurs when the performance archiver fails to startup.
Corrective Action
(None).
Syslog Message
Performance archiver failed to startup.
reason (STRING): Reason for failure to startup
perf.ccma.stop
Severity
NOTICE
This message occurs when the performance archiver is disabled.
Corrective Action
(None).
Syslog Message
Performance archiver stopped.
(None).
