perf.ccma events
perf.ccma.off
- Severity
ALERT
- Description
This message occurs when the performance archiver is not enabled, which makes it difficult for technical support to troubleshoot performance issues on the system.
- Corrective Action
Enable the performance archiver to track system activity and allow technical support to troubleshoot performance problems by running the "statistics archive config modify -is-enabled true" command. Note that the performance archiver is disabled during takeover and giveback, and in a failure scenario when the archiver loses communication with the Counter Manager Quota Management system; these two scenarios do not resolve by administratively enabling the archiver.
- Syslog Message
Performance archiver is not enabled for datastore '%s'.
- Parameters
datastore (STRING): Datastore name.
perf.ccma.startupFailed
- Severity
ALERT
- Description
This message occurs when the performance archiver fails to startup.
- Corrective Action
(None).
- Syslog Message
Performance archiver failed to startup.
- Parameters
reason (STRING): Reason for failure to startup
perf.ccma.stop
- Severity
NOTICE
- Description
This message occurs when the performance archiver is disabled.
- Corrective Action
(None).
- Syslog Message
Performance archiver stopped.
- Parameters
(None).
