ONTAP EMS reference
perf.ccma events
perf.ccma.off
Severity
ALERT
This message occurs when the performance archiver is not enabled, which makes it difficult for technical support to troubleshoot performance issues on the system.
Corrective Action
Enable the performance archiver to track system activity and allow technical support to troubleshoot performance problems by running the "statistics archive config modify -is-enabled true" command. Note that the performance archiver is disabled during takeover and giveback, and in a failure scenario when the archiver loses communication with the Counter Manager Quota Management system; these two scenarios do not resolve by administratively enabling the archiver.
Syslog Message
Performance archiver is not enabled for datastore '%s'.
datastore (STRING): Datastore name.
perf.ccma.startupFailed
Severity
ALERT
This message occurs when the performance archiver fails to startup.
Corrective Action
(None).
Syslog Message
Performance archiver failed to startup.
reason (STRING): Reason for failure to startup
perf.ccma.stop
Severity
NOTICE
This message occurs when the performance archiver is disabled.
Corrective Action
(None).
Syslog Message
Performance archiver stopped.
(None).
