The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
nblade.vscanconninactive events
Creating your file...
Your file is ready
Nblade.vscanConnInactive
- Severity
NOTICE
- Description
This message occurs when ONTAP® detects a nonresponsive antivirus (AV) server and forcibly closes its vscan connection.
- Corrective Action
Ensure that the AV Connector, installed on the AV server, can connect to the Vserver and receive the scan requests.
- Syslog Message
For Vserver "%s", ONTAP® forcibly closed the vscan connection originated from the nonresponsive AV server "%s".
- Parameters
vserverName (STRING): Vserver associated with this operation.
scannerIp (STRING): IP address of the AV server.
object_type (STRING): Type of the resource object under notification.
object_uuid (STRING): UUID of the resource object.
