nblade.vscanconninactive events
nblade.vscanconninactive EMS events occur when ONTAP® detects a nonresponsive antivirus (AV) server and forcibly closes its vscan connection.
Nblade.vscanConnInactive
- Severity
NOTICE
- Description
This message occurs when ONTAP® detects a nonresponsive antivirus (AV) server and forcibly closes its vscan connection.
- Corrective Action
Ensure that the AV Connector, installed on the AV server, can connect to the Vserver and receive the scan requests.
- Syslog Message
For Vserver "%s", ONTAP® forcibly closed the vscan connection originated from the nonresponsive AV server "%s".
- Parameters
vserverName (STRING): Vserver associated with this operation.
scannerIp (STRING): IP address of the AV server.
object_type (STRING): Type of the resource object under notification.
object_uuid (STRING): UUID of the resource object.
