ONTAP EMS reference
wafl.online events
wafl.online EMS events occur when ONTAP encounters issues associated with volume online operations and compatibility.
wafl.online.admin.vol
Severity
INFORMATIONAL
This message occurs when a cluster admin volume comes online during MetroCluster™ switchover.
Corrective Action
None.
Syslog Message
Cluster admin volume %s DSID (%08x) in aggregate %s is online.
vol (STRING): Name of the volume.
dsid (LONGINT): Unique identifier (DSID) of the volume.
aggr (STRING): Name of the containing aggregate.
wafl.online.fail.vmalign
Severity
EMERGENCY
This message occurs when a virtual volume cannot be brought online because it has the 'vm-align' option set, which is not supported in this release of Data ONTAP®.
Corrective Action
Install a version of Data ONTAP that supports the 'vm-align' option, available from your vendor.
Syslog Message
Volume '%s%s%s%s' is being taken offline because it has the 'vm-align' option set, which is not supported in this version of Data ONTAP.
owner (STRING): Volume owner.
vol (STRING): Volume name.
app (STRING): Application UUID.
volident (STRING): To uniquely identify the volume in cases where the volume name itself is insufficient.
wafl.online.infoError
Severity
ALERT
This message occurs when there is a problem reading the volinfo or fsinfo data while trying to mount an online volume.
Corrective Action
(Call support).
Syslog Message
Neither volinfo block of %s %s%s%s%s is valid OR the fsinfo block is invalid.
type (STRING): Type of object (volume/aggregate).
owner (STRING): Owner of the volume.
volident (STRING): Unique identifier of the volume in cases in which the volume name itself is insufficient.
wafl.online.mode.corrupted
Severity
ALERT
This event is issued when there is an inconsistency in the mode bits that indicate whether this volume is in a clustered or nonclustered environment.
Corrective Action
Run wafliron on the containing aggregate to fix up the mode bits.
Syslog Message
The mode bits that indicate whether the %s '%s' volume is in a clustered or nonclustered environment are inconsistent.
type (STRING): Type of object (flexible volume).
vol (STRING): Name of the flexible volume.
wafl.online.notCompatibleVer
Severity
EMERGENCY
This message occurs when a volume or aggregate cannot be brought online because SnapLock® is not supported on this version of Data ONTAP®.
Corrective Action
Install a version of Data ONTAP that is supported with SnapLock, available from your vendor.
Syslog Message
%s %s%s%s%s is being taken offline. SnapLock is not supported on this version of Data ONTAP.
type (STRING): Type of object (volume or aggregate).
volident (STRING): Unique identifier of the volume in cases where the volume name itself is insufficient.
wafl.online.toomany
Severity
ALERT
This message occurs when an attempt to bring a volume online fails because the maximum number of volumes are already online for this node.
Corrective Action
Take a currently mounted volume on this node offline so that you can bring the new volume online.
Syslog Message
%s %s%s cannot be brought online because the maximum online count has been reached.
wafl.online.unknownVersion
Severity
ALERT
This message occurs when mounting an online volume reveals that the volume version is not recognized by the current version of Data ONTAP®.
Corrective Action
Confirm that the correct Data ONTAP version is in use; if not, reboot or upgrade to the correct version as necessary. For more information or assistance, contact NetApp technical support.
Syslog Message
This version of Data ONTAP does not recognize the filesystem of %s %s%s%s%s. The volume is being taken offline.
wafl.online.unsup.deployment
Severity
ALERT
This message occurs when the system determines that the deployment in which this aggregate was created does not match the current (clustered or nonclustered) deployment of Data ONTAP®.
Corrective Action
Bring the aggregate online on a node that matches the clustered or nonclustered deployment in which it was created.
Syslog Message
This deployment of Data ONTAP does not support the file system of '%s %s'. It is being taken offline.
type (STRING): Type of object (aggregate).
vol (STRING): Name of the aggregate.
wafl.online.vbnMismatch
Severity
EMERGENCY
This message occurs when there is an error in the block number data associated with a volume, for example, if WAFL®and RAID have different values for the size of the volume.
Corrective Action
Run wafliron on the volume. For more information or assistance, contact NetApp technical support.
Syslog Message
There is a block number error in either the fsinfo block or disk labels on %s %s%s%s%s. The volume is being taken offline.
