wafl.online events
wafl.online EMS events occur when ONTAP encounters issues associated with volume online operations and compatibility.
wafl.online.admin.vol
- Severity
INFORMATIONAL
- Description
This message occurs when a cluster admin volume comes online during MetroCluster™ switchover.
- Corrective Action
None.
- Syslog Message
Cluster admin volume %s DSID (%08x) in aggregate %s is online.
- Parameters
vol (STRING): Name of the volume.
dsid (LONGINT): Unique identifier (DSID) of the volume.
aggr (STRING): Name of the containing aggregate.
wafl.online.fail.vmalign
- Severity
EMERGENCY
- Description
This message occurs when a virtual volume cannot be brought online because it has the 'vm-align' option set, which is not supported in this release of Data ONTAP®.
- Corrective Action
Install a version of Data ONTAP that supports the 'vm-align' option, available from your vendor.
- Syslog Message
Volume '%s%s%s%s' is being taken offline because it has the 'vm-align' option set, which is not supported in this version of Data ONTAP.
- Parameters
owner (STRING): Volume owner.
vol (STRING): Volume name.
app (STRING): Application UUID.
volident (STRING): To uniquely identify the volume in cases where the volume name itself is insufficient.
wafl.online.infoError
- Severity
ALERT
- Description
This message occurs when there is a problem reading the volinfo or fsinfo data while trying to mount an online volume.
- Corrective Action
(Call support).
- Syslog Message
Neither volinfo block of %s %s%s%s%s is valid OR the fsinfo block is invalid.
- Parameters
type (STRING): Type of object (volume/aggregate).
owner (STRING): Owner of the volume.
volident (STRING): Unique identifier of the volume in cases in which the volume name itself is insufficient.
wafl.online.mode.corrupted
- Severity
ALERT
- Description
This event is issued when there is an inconsistency in the mode bits that indicate whether this volume is in a clustered or nonclustered environment.
- Corrective Action
Run wafliron on the containing aggregate to fix up the mode bits.
- Syslog Message
The mode bits that indicate whether the %s '%s' volume is in a clustered or nonclustered environment are inconsistent.
- Parameters
type (STRING): Type of object (flexible volume).
vol (STRING): Name of the flexible volume.
wafl.online.notCompatibleVer
- Severity
EMERGENCY
- Description
This message occurs when a volume or aggregate cannot be brought online because SnapLock® is not supported on this version of Data ONTAP®.
- Corrective Action
Install a version of Data ONTAP that is supported with SnapLock, available from your vendor.
- Syslog Message
%s %s%s%s%s is being taken offline. SnapLock is not supported on this version of Data ONTAP.
- Parameters
type (STRING): Type of object (volume or aggregate).
volident (STRING): Unique identifier of the volume in cases where the volume name itself is insufficient.
wafl.online.toomany
- Severity
ALERT
- Description
This message occurs when an attempt to bring a volume online fails because the maximum number of volumes are already online for this node.
- Corrective Action
Take a currently mounted volume on this node offline so that you can bring the new volume online.
- Syslog Message
%s %s%s cannot be brought online because the maximum online count has been reached.
- Parameters
wafl.online.unknownVersion
- Severity
ALERT
- Description
This message occurs when mounting an online volume reveals that the volume version is not recognized by the current version of Data ONTAP®.
- Corrective Action
Confirm that the correct Data ONTAP version is in use; if not, reboot or upgrade to the correct version as necessary. For more information or assistance, contact NetApp technical support.
- Syslog Message
This version of Data ONTAP does not recognize the filesystem of %s %s%s%s%s. The volume is being taken offline.
- Parameters
wafl.online.unsup.deployment
- Severity
ALERT
- Description
This message occurs when the system determines that the deployment in which this aggregate was created does not match the current (clustered or nonclustered) deployment of Data ONTAP®.
- Corrective Action
Bring the aggregate online on a node that matches the clustered or nonclustered deployment in which it was created.
- Syslog Message
This deployment of Data ONTAP does not support the file system of '%s %s'. It is being taken offline.
- Parameters
type (STRING): Type of object (aggregate).
vol (STRING): Name of the aggregate.
wafl.online.vbnMismatch
- Severity
EMERGENCY
- Description
This message occurs when there is an error in the block number data associated with a volume, for example, if WAFL®and RAID have different values for the size of the volume.
- Corrective Action
Run wafliron on the volume. For more information or assistance, contact NetApp technical support.
- Syslog Message
There is a block number error in either the fsinfo block or disk labels on %s %s%s%s%s. The volume is being taken offline.
- Parameters
