ONTAP EMS reference
coredump.job events
coredump.job EMS events occur when ONTAP encounters issues associated with automatically saving cores.
coredump.job.notstarted
Severity
ERROR
This message occurs when the system cannot automatically save a core.
Corrective Action
Use the 'system node coredump save' command to save the core.
Syslog Message
(None).
(None).
coredump.job.notswitchedback
Severity
ERROR
This message occurs when the system cannot automatically save cores because a MetroCluster(tm) switchback was not performed.
Corrective Action
Return storage to the MetroCluster member by using the "metrocluster switchback" command, and then use the "coredump save-all" command to save any unsaved cores.
Syslog Message
System cannot automatically save cores because a MetroCluster switchback was not performed.
(None).
