coredump.job events
Creating your file...
Your file is ready
coredump.job.notstarted
- Severity
ERROR
- Description
This message occurs when the system can not automatically save a core failed.
- Corrective Action
Use the 'system node coredump save' command to save the core.
- Syslog Message
(None).
- Parameters
(None).
coredump.job.notswitchedback
- Severity
ERROR
- Description
This message occurs when the system cannot automatically save cores because a MetroCluster(tm) switchback was not performed.
- Corrective Action
Return storage to the MetroCluster member by using the "metrocluster switchback" command, and then use the "coredump save-all" command to save any unsaved cores.
- Syslog Message
System cannot automatically save cores because a MetroCluster switchback was not performed.
- Parameters
(None).
