ONTAP EMS reference
nvme.card events
nvme.card EMS events occur when ONTAP encounters issues associated with NVMe caching modules.
nvme.card.degraded
Severity
ERROR
This message occurs when the NVMe caching module has gone into a degraded state due to a warning reported by the drive. Performance, integrity, or reliability may be compromised.
Corrective Action
Replace the NVMe caching module.
Syslog Message
NVMe caching module in slot %s with serial number %s, and model number %s is degraded with status 0x%llx.
slot_subslot (STRING): PCI slot of the NVMe device.
serial (STRING): Serial number of the controller.
model (STRING): Model number of the controller.
reason (LONGINTHEX): Internal reason why the card is degraded.
nvme.card.removed
Severity
ERROR
This message occurs when an NVMe drive has been "hot-removed" from the system (while the system was powered on). The caching module is unavailable and system performance will be degraded.
Corrective Action
Insert an NVMe caching module into the system.
Syslog Message
NVMe caching module in slot %s with serial number %s, and model number %s was removed from the system.
