ONTAP EMS reference
savecore.nospace events
savecore.nospace EMS events occur when savecore has determined that the space available for storing the unsaved core is not sufficient.
savecore.nospace
Severity
ERROR
Savecore has determined that the space available for storing the unsaved core is not sufficient.
Corrective Action
Delete old or unneeded files in the root filesystem. Check in "/etc/crash" ("/crash" on Netcaches) for unneeded cores. Make sure to delete any snapshots that include the deleted files.
Syslog Message
The available disk space (%u blocks) is not sufficient to save the core, which may need up to %d blocks.
avail (INT): Number of blocks available for saving the core
needed (INT): Number of blocks needed for saving the core
