The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
savecore.nospace events
Creating your file...
Your file is ready
savecore.nospace
- Severity
ERROR
- Description
Savecore has determined that the space available for storing the unsaved core is not sufficient.
- Corrective Action
Delete old or unneeded files in the root filesystem. Check in "/etc/crash" ("/crash" on Netcaches) for unneeded cores. Make sure to delete any snapshots that include the deleted files.
- Syslog Message
The available disk space (%u blocks) is not sufficient to save the core, which may need up to %d blocks.
- Parameters
avail (INT): Number of blocks available for saving the core
needed (INT): Number of blocks needed for saving the core
